My cockpit fridge in my 2005 320 FV stopped working.
Does anyone know what I can use to replace this? The brand I have now is not made anymore.
Waeco fridge only works on DC — Rinker Boat Company (vanillacommunities.com)
I also fixed my old one and selling it as well (although you'd have to live nearby cause shipping would be too expensive).
Fridge Freezer Thermostat Refrigerator Cold Temperature Control Universal WPF-20
https://www.amazon.com/Thermostat-Refrigerator-Temperature-Controller-Universal/dp/B07V2ZQ6JX?th=1-3°C to -20°C(26.5°F to -4°F)
Changed both of mine to these. If you look at others look at the temp range.
If you put in a higher temp range it wont get cold enough
The cockpit fridge is probably grounded to an 18-year-old ground block in the engine room that has about 20 wires attached with corroded, unsealed crimp connectors. Consider re-making those connectors to improve reliability. On most boats, it's a fairly easy DIY if you have the right tools.
To do it right, you need three things.
A ratcheting crimper like this:
https://www.amazon.com/Klein-Tools-Ratcheting-Crimper-10-22/dp/B07WMB61J5
Heat-shrink ring terminals like this (don't skimp, get good ones or you'll regret it):
https://www.amazon.com/Haisstronica-Connectors-Tinned-Connectors-Heat-Connectors-Insulated-Electrical/dp/B08HRTVLCQ
A heat gun (or, in a pinch, a butane lighter)
The job is easier if you also get a one-handed wire stripper like this:
https://www.amazon.com/Self-Adjusting-Stripper-Klein-Tools-11061/dp/B00CXKOEQ6
On my boat, they had jammed 3 or even 4 wires into a single terminal. It's best to have no more than two in a terminal, and no more than four terminals on each screw.
This is a good mod -- easy, not expensive, and very satisfying.
