AC Fan Slowing Down
Hello all, this is our first year with a 2004 270 FV, we love it and all systems seem to work fine and our AC was great until last weekend. Water is running through it fine, but after a couple of hours running the fan (on Auto or manual fan speeds) slows to a trickle of airflow coming out of the vent, not nearly enough to cool off the cabin. I have to put my hand right up to the vent to even feel anything coming out.
I checked the intake vent and the filter seems fine, there is a white plastic wall behind that which is very very cold. I have a feeling maybe the fan is bad? What is that wall? Except once it's been off for a few hours it will run ok again until it slows down again like before. Anyone had this problem or know what to check? Is there a way to blow a fan through there to see if that's the problem?
Thanks ahead of time!
2004 270 Fiesta Vee - Bull Shoals Lake, AR - 350 Mag Bravo 3
Named her "FAMILY THERAPY"
Best Answers
Optionsraybo3 Administrator Posts: 5,461 adminNext time this happens check the unit and see if its frozen. My guess is your unit is turning into a block of ice. Check it out and keep us posted. Also welcome to the RBOC.2002 342 Fiesta Vee PC Point Of Pines YC Revere MA. popyc.org raybo3@live.com
OptionsBlack_Diamond Member Posts: 5,439 ✭✭✭✭✭The unit is freezing up, so zero air flo. You can adjust the programming to prevent this. There are several threads on here about that or look up your controller instructions. For short term: turn it off to melt.Past owner of a 2003 342FV
Mike
Hello all and thank you for your answers. After messing with this a bit it is absolute that the cold white wall behind the intake vent is indeed the evaporator (looks like a radiator?), with no airflow it had turned to solid ice!
I'm going to guess it's not too low on freon? Where I'm at is a beautiful clear lake, and no Marine AC guys at all. Matter of fact we're one of the few cruisers on the lake at all, the only boats bigger than us are houseboats, lol. Here's our newest cove:
LOVE OUR RINKER!
Anyway, I'm handy but kinda on my own to diagnose and no tools of the trade so to speak.
However, I believe Babyboomer may be onto something with the bad fan. Works like a champ at first, for about an hour or two. I'm guessing again, that the fan is slowing down after it gets heated up for awhile and the evaporator freezes, making it even worse. With the summer heat coming on I'd like to figure it out. I've got a small electric fan that fits perfect in front of the intake vent, so I'm just going to turn it on next and see what happens. That should at least tell me if its a fan issue?
Didn't try just the fan Weber, although I should, that's a good diagnostic idea. For the 4th our family of 5 stayed on the boat 5 days and I had just hooked up a small 10" square box fan in front of the intake vent and the AC ran all night just fine. I have a feeling I'll be replacing the fan unit.
We watched 3 different fireworks shows in different cities on the lake each night, never watched those on the water before, was really cool. 90 miles we traveled!
