276 batteries - Which one is the deep cycle and cranking?
                    Hi all,
Just bougth a 2016 276 BR and I am looking to replace the batteries. In the engine compartment one battery is fore and one aft. Which battery is the deepcycle and which one is the cranking battery? I assume the deep cycle is the one that is correltated to the "On" position on the battery switch?
Thanks!
Thanks!
Deep cycle is a battery technology (type of batteries) that allows the user to discharge it more "deeply", to a lower state of charge ... doesn't necessarily refer to the position it is used in. Lead-acid batteries don't do well if you discharge them consistently below 70% ... it starts to destroy the chemicals within the battery, and it loses capacity. It's okay in the starter position because you would draw very little capacity out of the battery to start the engine, and then the alternator will kick in the recharge. A deep cycle, on the other hand, can be discharging to feed the radio, fridge, etc ... without the engine running ... and so you want a technology, like gel batteries, that isn't going to get damaged when you discharge it to a low capacity state (like down to 20% capacity). Every battery has it's limits ... if they are overcharged or over-discharged ... the materials within get damaged.
Of course, we would recommend a high-amperage cell for the crank, and a deep cycle for the HOUSE battery. So are you asking which one is the crank/starter and which one is the house battery?
A deep cycle will come with certain markings like 27D, 31D, AGM, Gell Battery.
The next thing to note is, you cannot rely on someone else's position of batteries. It could easily be wired up differently for you. Best test is to disconnect one of the batteries (remove cable safely) ... and see what has power.
If I turn on the radio, and remove one of the battery cables and the radio goes off, that one should be a deep cycle battery? Is my thinking correct?
Thanks
Radio, cockpit lights, nav/anchor lights, blower, etc. Most of those should be running on the ‘House’ battery.
Lead acid, AGM, Lithium all have slightly different charging requirements.
On our 276BR we had a charger installed at the dealer. Worked well…..
So you have three batteries?
Where did you mount the ProSport 20 in the engine compartment?
