1 drive only went halfway down
SpyderwebSpyderweb Member Posts: 959 ✭✭✭
Spent the day in relatively shallow water so had drives all the way up just to be cautious.  End of day, using the single trim button (versus 2 separate drive buttons on handles) I dropped the drives, waiting for change in sound to know they were all the way down, as I always do.  Slowly motored out of the bay then increased throttles to get on plane.  Around 3000, 1 engine revved way higher than other and I immediately dropped  them both back down.  Thought maybe weeds on 1 drive, so reversed to knock them off and tried again.  Same  thing happened.  Then I noticed my trim gauges (which I rarely consult, just not fine tuned enough to be useful) and noticed 1 drive all down, and the other only half down. WHAT?  How’s that possible using one button.  Using same button, I raised drives all up, then all draw, and this time both went full down as expected.  Trip back to dock was fine.
Next morning I tried at dock and could not duplicate problem.  Everything was fine.  What happened there?  Have I got a problem  and need to worry?
  • YYZRCYYZRC Member Posts: 5,501 ✭✭✭✭✭
    I have had that happen before. I figured it was because there was some air in the lines/rams that was being purged when lifting the drives all the way up (trailering height). Since then I always drop each drive individually and listen as you do when I have had them all the way up.
    Check fluid levels in trim pump reservoirs?
    Both trim reservoirs full.
    Might just check connections as survey it will raise its head again one day...
    Yeah, that seems to be the way things work.  Was up again a week ago and all was good.
