AC not drawing water 2006 FV270
So yesterday my air conditioner seem to have lost prime? We used it last weekend with no problems. Clicked it on yesterday and it is not drawing water. I disconnected the hose to the sea strainer and it is freely letting water in. What should I try next?
I have flushed with barnacle buster 2 times for more than an hour.. thing wont run over 90 degrees water inlet temp.
We turned on the AC last night as I was finishing dinner. By the time dinner was done and Ace Ventura pet detective 2 call of the wild was rolling credits it went down from around 93 to 72 degrees. We keep the thermostat set at 70... because I'm a dad and that's reasonable. The best part is how low of amps it draws. My genkins 3800 watt inverter generator ran from approximately 10pm night until 5:30 am before running out of fuel. This was running 3 battery chargers and two fans. The genkins holds @2 gallons of gas. I go through maybe 6-7 gallons of gas a weekend running the AC. We run it around 12 hours a night
Have you by chance asked your dock neighbors if their ac was still working? On my last trip to the rock all the live aboards were still running their AC during the day despite 90 degrees water temps killing coral, conch and crabs and near 100 degrees daytime temps.
I question the sizing your system as my home heat pump and less than ideal quagmire of an vw/Toyota hybrid ac system still perform well even as air temps surpass 95 degrees.
This is what is currently installed: https://www.amazon.com/Fountain-Stainless-Bronze-Compatible-FCP517011-20/dp/B09G5WG296/ref=sr_1_25?crid=2KPXRXY4RN1GQ&keywords=Little+Giant+1200+gph&qid=1691453921&s=lawn-garden&sprefix=little+giant+1200+gph,lawngarden,101&sr=1-25
Dunno what difference it makes or why you'd want slower moving water... but like I said, I already have the first one, will give it a shot.
Hate going into something knowing it's prob not going to work.
How is the tap water?
I've mentioned in another thread that I will run my ac on a garden hose when having to do cabin repairs in the heat of the summer. Maybe try to do that and see how it works. I doubt the ground temps from the tap water is more than 80 or so degrees.
