How to run wire from engine bay to dash?
Can anyone help me with the proper way to route/run a wire from the engine bay to the dash? There is a firewall and its tricky to tell what the right path to the cockpit is. I have a 2007 Rinker 250. Thank you!
I just ran a transducer cable on my 2004 250FV and it was very easy. All my cables run down the starboard side, if you open the engine hatch, remove the trash can that is above the cooler, remove the big screw in plug right next the helm seat, and I removed the instrument panel. With these out, you can reach everything. It took me about 15 minutes. Of course your 2007 my be different.
Good luck.
