Engine water Pressure
Bmaggiac
Member Posts: 30 ✭
I have a 2008 Rinker 330 EC with 350 mag mpi and bravo 3 sterndrives.
I got an alarm with vesselview saying "engine power limited" with "11' in the top right corner. I was told this is a water pressure issue. Check the water pressure and at idle (600 rpm) the water pressure was 8.8 port and 0.8 starboard. I swapped the sensors and the higher pressure moved to the starboard from port. This to me seemed to be a bad sensor so I replaced both sensors. I tested the engines at idle and the pressure is 18.0 port and 20.2 starboard. They both seem consistent with each other. Does anyone know if this is okay?
Best Answers
YYZRC
Member Posts: 5,479 ✭✭✭✭✭
Mine read 1psi at idle and 8psi at 4000+ rpm. Impellers are new this year and have around 50 hours on them this season.
Georgian Bay -
Pat310
Member Posts: 605 ✭✭✭
Did you buy OEM or Chinese knock offs? I tried the cheap ones and one read zero all the time and the other read 40psi even with the engine not running. LOL. Paid the extra and put in OEMs. Lesson learned
