Fresh water pump
ok, it looks like my fresh water pump keeps kicking on just for a little (1 sec or so) about every 4-5 minutes. I know, sounds like a small leak somewhere. Well, I spent the last 10 days on the boat, and this was going on for about the last half. I've dried that bilge and looked in every nook & cranny possible...does not seem like a leak. & does not seem like water is leaving the fresh water tank.
So, I hadn't looked real close at the pump, but is there a screw adjustment maybe for pressure? I'm also wondering if there is possibility of air. My thought is since I always use my fresh water tank, except when I'm on our long trips, maybe hooking up the 'city' hookup introduced air. But yet, you'd think it would escape out after some point of use (only location that water wasn't turned on was the aft shower - maybe it has air). I also saw a small bubble of air in the filter right at the pump, so maybe that is it?
One more thing, if the 'city' water is on as well as the pump, I don't get pump noise. I know, it sure sounds like a leak somewhere, but all is towel dry in the bilge & other areas I can see.
I just thought it'd be a few days till I get back to the boat and I'd look for ideas. I'd love to replace that loud pump, but I'm not sure it is a problem.
I think there is a check valve if it allows water to leak back away from pressure switch it would act like that. I'm not positive though, on your set up
Did you check to see if its leaking from the shore hook up regulator? It could be leaking out side the boat.......
I would assume if the check valve was bleeding off when you put city water pressure with a hose on it would back feed and starting filling your tank.
You are both correct. I only had the city water hookup on when we were on the boat, and always had it off while we slept at night. So, each day it probably wasn't on more than a couple hours. It definitely could've leaked back in the tank. I'll definitely let you all know what I find. I'm planning on heading to the boat Thursday morning, depending on weather (we may be getting a bunch of rain).
Sure is, & I'll probably go down to do it even in the rain. Just not sure that I'll talk the admiral to come down later when she's done working if it's raining. I guess if it's raining I can just take advantage as well and not have to use the hose to scrub clean the boat too.
We have a 2007 370 and I experienced the same thing and I tracked to the shower diverter in the head. I took out the storage bin , shelf. or whatever you want to call it in the shower and behind it was the connections to the diverter. I just gave it a little turn with the pliers and that was that. It wasn't til we went to a marina on the Jersey shore with a lot of pressure at the dock that exasperated the leak that I was able to identify it.
"Pipe Dream"
2002 Rinker 342 Fiesta Vee
2 x 350 MAG MPI Horizon Petrol
"Pipe Dream"
"Pipe Dream"
Look for a cylinder 4" diameter, 10" tall with two hoses.
Out of interest does anyone know what the changes were between a 2002 and 2003 model 342 FV?
"Pipe Dream"
CaptianDan, did you add your washdown pump? If so, where did you draw the water from? I was thinking of adding one and using the water inlet for the genny since it's in the neighborhood. Assumed I'd need a tee and a check valve or some such. Any hints would be helpful.
@stodge, the washdown pump was already fitted when I brought the boat and I think it's connected via the water heater but I will check on the weekend when I'm next at the boat.
"Pipe Dream"
"Pipe Dream"
