Replacing Perko Fuel Fill Ports - has anyone done this?
echandler1971
Member Posts: 233 ✭✭✭
Hello, so after getting close to 30 gallons of water out of my tanks on my 05 360, the culprit being bad gaskets and a known flaw in their flush-mount ports, I have 2 new ones ready to install along with the plastic offset pieces that will allow water to rain-gutter around the face of the port that is otherwise nearly flat on the transom. My question is, has anyone replaced theirs and were they able to do it from the swim platform alone, or did they have to dislocate body parts to crawl into tight spaces in the engine compartment to loosen the gas and vent hose clamps? My hope is that there's just enough slack to allow someone in the engine bay to hold up on the 2 hoses enough that they and the clamps pop out the transom for an easy swap. Hopefully I explained this well enough. Currently I have tape over the old ports so I don't end up where I started.
Dan of Steel
'05 Rinker 360 Fiesta Vee
Perko Fuel Fill Ports and the oring part number thanks.
0540DPGCHR Is the part number for the bent neck version.
flush-mount version we have. New ones have offset adapters to mostly eliminate this problem.
pulled cool fuel filters and put in new filters. when I opened fuel line valve to fill bowl in cool fuel thought I heard the gas suck back to tank. couldn't gas gas to flow to prime filter. added gas to both tanks and had to manually prime, once pumps primed everything was fine. added 46 gal to both tanks and ran each engine from its own tank ran great.
Weird problem I will check to make sure starboard tank gas cap is vented.
