Secondary Fuel Water Separators Installed
With a lot of over engineering and innovation, I was able to squeeze two fuel water separators into a cramped engine room. Given where the fuel lines were, and my hope to just reuse what was there, I went ahead and did what I did to best inline these things. That cantilevered setup isn’t going anywhere. That aluminum rail is strongly attached on the other side, and will not rip out.
I did this because I am the guy who had 30 gallons of water just pumped out of my gas tanks. They did a number on the engines and injectors. I’ve solved the water getting in the gas problem, but I want to make sure I’m ready for the future when condensation and everything else adds a little bit of water to the tanks.
Dan of Steel
'05 Rinker 360 Fiesta Vee
I also had a water problem or still do,- anyway- I was testing my no start and hooked up line to that shader valve on the fuel rail and was pumping significant water...some trash into my little bottle. I really question what good the filters are doing as next stop from fuel rail is the injectors and then a cylinder.
