seeking refrigerator model number
tcooktcook Member Posts: 3
Hoping someone can help me!  I just purchased a 2000 330 FV.  It does not have the original galley refrigerator in it.  I would like to install the correct refrigerator, but cannot find a model number to order the correct one....
Can anyone help?  Thanks!
  • tcooktcook Member Posts: 3
    The local rep asked for the number i guess for cross reference to current.  Maybe someone with a 98,99,00 330 might check theirs for me?
    Thanks to anyone who might be able to help!
  • rmrstlmormrstlmo Member Posts: 232 ✭✭✭
    I have a 2000 340 FV.  I'll check this weekend.
    Ray
    2006 390
    Previous 2000 340
    DE-490 is the model number for my 2000 340.  Good luck.
    Ray
    2006 390
    Previous 2000 340
    Thanks very much.  I had decided to use just the opening dimensions, but this will be an even better cross check.
    Much Appreciated!
  • gearshiftgearshift Member Posts: 13 ✭✭
    a few years ago the fridge in my 260 FV stopped working on DC. I took the fridge home and started troubleshooting it. I found that I required a new PC board for $350.00. A new Norcold was nearly $1000.00. I decided that I would run the fridge on an inverter. On AC it only draws 60ma. Been fine for 3 years. The reason I'm sharing this with you is you can get an AC fridge for less than $150.00. Look around for the size you need. Just pay attention to venting (air flow)
    I agree you will have trouble finding that exact model. I have trouble finding things after only 4 year in the market - things are changing that fast.  I would go with opening size and find something new to fit. As gearshift states, you have a great opportunity to put in an inverter and get a cheaper fridge.  My friend did that, he even got a bigger fridge out of it!
