network
I have a 2008 Rinker 330 ec with twin 350 mag mpi. My Raymarine C80 MFD gave up and I replaced it with a Raymarine Axiom +9 RV. Installed it later part of last summer.
it keeps loosing fix and I was told I need to add a RS150 receiver on my arch to capture the signal properly. In order to do this I need to add the MFD and RS150 to a network. Apparently, you can't connect the antenna to the MFD directly without a network of some sort.
Is there a network existing on the Rinker that I can tap into? If so where is it?
Or do I need to add NMEA 2000 to accommodate to MFD and antenna.
To add the NMEA 2000 is quite expensive and would like to avoid if possible.
Any ideas?
Any ideas?
You should just need the "backbone" and some network cables. Looks like the starter kit is less than $200.
If you have nothing currently using your network plug on your MFD you should be able to plug the antenna directly to that seatalk port..... possibly.
