Kholer Genset Axial Fan
oscar1
Member Posts: 790 ✭✭✭
My local kholer generator has the following Axial fan install on top of the generator enclosure to remove heat from the unit on display. It look good, but I don't know if it is a good upgrade for the generator. I normally run the genset with the from door of the enclosure open, so I can see the unit running with my ENG Room camera for any abnormally issue at night. What do you think about it?
Doesn't the generator get louder when you open the front panel? The only purpose of the enclosure is to control noise.
