docking
I have a 2006 Rinker 360 express cruiser with very few hours on the engine. The boat was hardly used. I purchased it last season in August. I have no problem leaving the slip, and navigating out to the open water, but I have a miserable time trying to dock the boat. I always need help, and even experienced boaters have a tough time docking her. The throttle levers are extremely sensitive. If I give too much gas the engines stall leaving me drifting in the marina. Is this normal with the out drives? They are Vovo Penta Titanium X. New last year. The engines are Volvo 8.1 Liters. I thought there may be some kind of adjustment on the linkage or somewhere which would give me more leeway in maneuvering. Need some good advice. Thanks, Larry
The engines should not die. I didn't have any problems docking my 342 with twin outdrives. I actually found them easier than v drives because I actually had more control the the Bravo 3's. Engines didn't have any problems stalling.
You definately have some type of problem wish I had a solution but I am sure someone on this board will be able to help
I have the same drive set up as you. The key is to have extremely smooh thottle cables. Are yours slightly stiff to move, forcing you to push harder then the throttes jump and the boat leaps to quickly?
You may need new cables or check for hard bends in the cable as the return to the engine or up to the dash. Volvo penta has a spray lube in a blue can. Try spraying all the linkage and exercise the cables with the throttles over and over. That may help smooth them out. This tends to happen when when a boat sits to long without use. She gets a little pissy...
LG
I have an 05 360 but with merc bravo3s. I had a problem with stalling while docking, any in and out of gear maneuvering, which made it a nightmare. Both of my IAC sensors were bad. A known issue with the merc 8.1s. Not sure if it's an issue with Volvos but worth investigating. The best money I ever spent was with a captain showing me the ropes of operating a larger vessel in close quarters and docking scenarios. The trick is to go slow. Keep the wheel straight and do your turning with the drives. Short bursts in and out of gear. Line the rear end up and the bow will ultimately follow. Do you have a thruster to assist?
To all who were kind enough to leave responses. I am getting a marine mechanic to check everything out. I have had many qualified boaters try to dock her, and they all had problems stalling. They did eventually get her into the slip, but it took more than a few times. I'm a novice, so you can imagine what I go through. Horrors!!! I'll post the next email after the boat is thoroughly checked out!!!!
The mechanic should settle down those engines....
You or anyone else should be able to dock with the engines in idle speed...unless you are fighting hard wind and current.
If it is stalling then something is definitely not right. I know Mercs have a switch that actually stalls the engine if not set correctly. It allows shifting to happen with an intermittent (real quickly) stall between gears. It will allow it to stall if not set correctly. As I said, not sure if your boat has this (not even sure if Merc still has them, I just remember this problem on one of my older boats).
As Dream Inn mentioned, Alpha drive Mercury Marine engines have what's called a "momentary kill" switch. It's designed to momentarily kill the engine to release gear bind in the out drive so that you can shift from forward to neutral to reverse and back. The switch is a micro switch that sits in the throttle rocker assembly and basically grounds the spark to the distributor. These switches can go bad and can also get out of alignment. Bravo drives do not have the momentary kill switches since they use cone clutches which can release gear bind. I don't know much about VP equipment - but that may be part of your issue.
let's talk about docking a bit more as the trip I'm fixing to take I will have to dock between two sets of poles with the dock to the transom. I've done it, but pretty stress full. Thing is, my wife wants to help but I don't really know how to tell her to help. So far, with similar docking there has been people at the dock to help with lines and I just stood back and watched. I have looked all over You Tube thinking I would find out step by step but not really out there. So far, everything has been perfect weather/wind/current conditions but that won't happen forever and again there have always been people to assist. At somepoint, I will have to tackle this by my lonesome and I'm very puzzled as to how to get the lines done on the front poles tied off and then get the boat symetrically placed between them. I understand the springline concept of keeping the boat in place once your secured but getting those lines on the front secured are a bit of a puzzle...last time a fellow jumped on board, kind of made a lasso and got the lines over the pole but they weren't really tied off tight at the pole and I was concerened they would slip down the pole and then have issue with the tides....was out there checking all night! Know of any sites that have docking in a slip 101 to review??? Tips?? I do well handling to boat but a few seconds of leaving the helm to deal with a line, the boat can move a lot!
Look up boating world magazine ( pretty sure of the name) they had some basics in a mag awhile back. Just remember don't panic and stay calm I know easier said then done. Practice is the best approach empty docks or tie some jugs up to make a dock in water. Never and I mean never worry about what people think that are watching everyone has had a bad docking experience if they say they haven't they're lying.
Boating is the name of the magazine look in the how to section lots of good articles for everything
Hey Ras - we go away for the winter to scuba dive. All of the dive boats go between pilings. They do a move they call "warping the line". They secure a line amidship to the entry piling and pivot the boat against the piling to line it up then just back in. I have heard this is a common method. Personally, I don't like it as I feel it could stress the hull. There have been some really good articles in boating magazines as JC290 suggested that deal specifically with pilings. I'll post a link if I can find one. On the practical side - I had to tie-up a number of times at a relative's slip that had pilings. I hated the friggin things. Sooo, I modified a telescopic boat hook that allowed the Admiral to slip a line over a piling from 10 to 12 feet away. It solved the problem 100%. I could have sold dozens of them. I believe there is just such a rig available now for sale - but you could easily just rig your own telescopic boat hook to do that. My rig was REALLY low tech, I used a cheap piece of velcro to attach the line to the end of the boat hook. The Admiral extended the boat hook with the line attached to it around the piling and brought it back to the boat then, while I held the aft line (or she cleated it loosely as I held the boat steady at the helm), she went up to the bow to do the same. I even did it once all by myself, but like you said I had to move a bit fast as it was windy. Best advice ever - like JC 290 said - don't give a cr*p what the dock lookers-on think. Take your time! I hope some of this helps. MT
My advice (maybe I've missed it on here already), as I am backing in, I have the admiral put the line on the piling that first is on the leeward side (wind blowing towards you). It will take practice, but you keep the bow near that piling until the line is on, then the wind or you will move the boat towards the other bow piling. Admiral can then put it on as well. We have a place here that has the huge tall pilings (Hyatt in Cambridge) and there is always a good crosswind. I was looking forward to finally take our boat this year cause I have the bow thruster to help out. I've gotta say, for once it worked out well. But, the bow was high enough with this boat that the admiral could also get the line over the top of the piling with ease.
I've also used the boat hook with a loop and put it on, but the admiral didn't really like that too much. Ras, all I can say is it takes time and practice. We have lots of those pilings up here and been doing it for 15 years, still a PITA!
A single engine 270 like yours w/o a bow thruster is a really challenging boat to pull/back into a tight slip because of the huge freeboard and lack of any bow control. I've found backing down is far easier, and much more convenient once tied off. Let the end with the engine lead the show. Here's a few single screw docking tips assuming an adverse breezy entry:
It's a learned behavior as you get accustomed to how the 270 reacts to wind but you will get it with some practice. Be safe, calm and easy on the throttle. The bow will swing away, all you can do is use those outside pilings as guides.
Mike
Well put tiki
thanks all for the input...I'll study this more carefully at home...at this point the admiral will not go on the bow so I will have to get her comfortable there while we are putting around perhaps and then we can progress! I know with the tides and wind, it's going to be a real challenge for sure....bow thruster would be sweet!
Mike's advice is golden!!!!! My highlights would be -The Admiral MUST always have a PFD on and a good pair of REAL boating shoes with soles that stay tacky, even on wet fiberglass, would really boost her confidence. I have read enough of your posts to have complete confidence in your ability to react in a calm and reasoned manner to wind and current. Getting everything ready ahead of time, before entering the harbour yet alone the fairway is super important.....and what we repeat here ad nauseum - practice, practice, practice in the open with your boat - in the wind backing down - turning sideways etc. etc. and on empty docks or pilings builds experience. I REALLY like that you are going out to have fun and not, like a lot of people, too afraid to venture to new areas - because IMO that's the whole reason of having a boat instead of a cottage. Go Ras! MT
Good advice Tiki. Staying calm is the most important thing. Most of the time, when I've done something wrong docking it's because I was panicking. If you get too close to something it's easy to push the boat away to avoid damage. As Tiki says keep calm and communicate clearly to everyone that is helping.
As a newbie, I had difficulty getting the boat turned 90 degrees out of the fairway to enter my slip. Just turning the wheel, aiming the bow and hoping for the best wasn't cutting it because of infinite variables of wind and current and the potential to over or under shoot. Then an old timer in a nearby slip gave me a great tip.
He said "son, with a single engine power boat with a sterndrive, the key to success in slow speed maneuvering is to learn to rotate a stopped boat on its own central axis." So how do you do this? Simply put the wheel hard over in the opposite direction you wish to turn the bow, and apply gentle reverse thrust and voila! the boat rotates. It is counter-intuitive to turn the wheel in the opposite direction you wish to move the bow at first, but you get used to it as you gain skill.
So now I just pull up with my bow level to the far side of the slip, stop, and do what he suggested. As soon at the bow is crossing the center of the axis of the slip, the wheel goes over to the same direction as the bow and a blip of forward thrust is applied. This works every time, even in 20 kt winds and strong currents. I haven't had a bad slip docking experience since I learned this. It may be obvious sterndrive 101 to the experienced among us, but for me as a rookie it was a real turning point and transformed my enjoyment of the boat.
Andy
I never ever put anyone on the bow of the boat when docking. I have my bow line with me at the helm and I am the one that "throws" it out. If you think your going to hit the boat next to you have someone hold a fender so you bump the fender and not the boat. The current runs up to 7 knots so I know about strong currents and winds....
Great opening statement DI. We get fabulous advice from many super guys ( and a few gals) who take time from their personal lives to help all of us. As is sometimes the case the advice may apply a bit differently in different contexts/locations. I do not like the Admiral on the bow. I particularly hate it when she refuses to a wear a pfd. However, when locking through our canal system you are required to have someone on the bow to hold a spring line that is looped around the lock's bow cables. I like it even less when someone is on the swim platform. I plead with the Admiral to wait to step onto the docks until I have shut-off the engines and counted to 5. I'd rather swap some gel coat with the dock than have her fall into the water and back into her. ....care to know how many close calls I have seen wherein the captain has dumped the admiral off the swim platform while docking and is then backing in towards her? Scary! For me - slow and easy with no fast moves. I'm pretty good - if not, I know a fabulous gel coat man. It's only $$$. MT :-)
All situations are a little different then the last wind current tide different marina. Best thing we all can do is absorb all the knowledge we can. Pass on what we learn and not assume we know everything. Ultimately it is on us to be as safe as we can and protect the crew. Perfect docking is priceless we all love it when you get the compliments on how easy we made look. Great lessons from all of you safe boating to all of you and good luck
all good info I will take in...just need to get out there and make it work!
X 2,this helps me every time I dock.
