Depth gauge
rasburyrasbury Member Posts: 8,856 ✭✭✭✭✭
Was the Faria depth Guage the std install on 270's along with their other gauges? I can see it, I see an image that looks like it on google- just did not remember it being Faria...I don't want to have to replace the transducer...
  • rasburyrasbury Member Posts: 8,856 ✭✭✭✭✭
    I guess this has to be what I had..
  • mbnarneymbnarney Member Posts: 190 ✭✭✭
    Ras, That's what came on mine. Its a 2001.
  • FormulabenFormulaben Confirm Email, Member Posts: 198 ✭✭
    My 2006 has the Faria.
    edited April 2024
    Thanks- I see a similar that says no longer available. I hope I don't have to re wire the boat because they updated stuff- what a mess! Pretty much have to order with a new transducer, just don't want to install it if I don't have to.
    When I was researching getting new guages I got the same and worse it seems you need a new thru hull as well. I am just going to use the depth finder on my Garmin
  • Lake_BumLake_Bum Member Posts: 1,120 ✭✭✭✭
    My 2000 is a Faria also.   I learned with other boats in the past, to never mount two different transducers too close together.  The beams will cross under the boat, and give really wonky results.
  • davidbrooksdavidbrooks Member Posts: 1,418 ✭✭✭✭
    It isn't as bad as you may think it is. The transducer itself comes with enough wire to very likely reach the helm and just directly plug into the gauge. I did it on mine and I actually just simply cut the old wire and beat the old transducer out with a big hammer. Then cleaned up the whole dropped in the new one. You do have to get a whole new setup. The old Faria used a different frequency that isn't used anymore. So your transducer isn't compatible with any new sensors.
    @davidbrooks it is not installed like a thru hull fitting,  a threaded nut on one side, flange on the out side, just glued on? I've never looked at it..
    Yep. Likely just plastic.  You can put a big channel lock on the nut inside. It is just not easy to get to with an engine in.  If you wack it really well with a large hammer or mallet you can beat it out. New ones are not quite the same diameter. So get a big tube of 5200 to seal in the new one.
    @davidbrooks- the 270 is not that bad- not spacious by any means but the 9' beam and the single motor dies have its advantages- speed not being one of them..
