Dash Redo 320
Dash redo 320
Sharing with the group an addition to my 320 from last summer which I will be completing before launch this spring and have a few questions that I’m hoping someone can help me with.
I made an aluminum dash housing with an axiom 12 Rv with transducers and fitted it to the existing dash. Set up a nmea 2000 network with fox marine engine gateways on each engine ( 5.0L Volvo penta engines) and raymarine GPS antenna as the one in the unit would not always get a fix. (Likely the housing interfering) To the left of the helm I made a new panel and installed a wireless cell phone charging pocket.
I will be adding either nmea fuel senders in the tanks to connect to the network on the axiom or piggy back off the original float level sensors. Suggestions?
i have removed all the panels now and will be painting them all which leads me to some questions before I complete the dash.
1) I have searched everywhere, can I convert my dps drives 3 wire tilt signal to NMEA 2000 to read on the Axiom with some sort of converter so I can eliminate those gauges?
2) my plan is to delete all the quad gauges to the right and left of the axiom the question is as I am cleaning up all the wiring ( what a mess! ) has anyone removed the gauge harnesses completely? Can someone identify for me a 3 inch round unit the shape of the gauges with two harnesses coming out. Numbers are worn off but it says gas module on it. Picture attached.
3) Anyone who has used a gateway and MFD to read everything have you completely removed all gauges?
Thanks.
What is the function of this below??
Thanks.
My boat being 2005 the inputs are all analog so I need a type of converter.
Worst case I will keep the two analog gauges for the trim and hook up fuel tanks to the MFD with the converters or new NMEA sending units.
thanks for the tips in my earlier posts to everyone who commented. GrahamU as always your advice is appreciated! Get back home so we can have dinner!
Fuel Gauges on axiom reads off of oceanic NMEA sensors
Out drives I used yacht devices rudder sensors and thanks to Andrew at tech support there.
New shifters plus cables and that was a good call as I always felt like I was fighting the boat. After launch to my slip there was a big difference shifting with ease. (Sloppy shifters combined with stiff cables not fun)
Epoxied old holes from Speedo tube and brackets mounted to back of transom. Resealed platform to boat, supports to transom and trim tabs.
Lots Of threads and topics about gauges not working and people wanting to redo I hope this helps anyone with their project.
