Is your Hardin Gen 7 sea water pump leaking? Pump rebuild/exchange service ...
LaRea
Member, Moderator Posts: 7,926 mod
If your Hardin Gen 7 sea water pump is leaking water from the drive shaft, contact me and I'll rebuild it for you. Or I can send you a rebuilt pump in exchange for your pump.
The price will depend on what you need and how soon you need it. You'll pay parts, shipping and a small labor fee. It will be cheaper than any commercial rebuild service, and cheaper than replacing the pump.
If the pump is leaking, it means the seals have failed, and water is getting into the bearings. You should stop using the pump immediately to avoid damaging the drive shaft. (I can replace a damaged shaft, but it costs more and takes longer.)
Send me a private message here on the forum.
@Alswagg is a former member who led development of the Rinker 342 back in the day. A few years ago, after I started rebuilding pumps, he sent me a pump with a leaking bearing. Told me to keep the pump as a spare, and wouldn't take any money for it. I rebuilt it, and that's the pump I sent you.
I do really miss having @Alswagg here. What a great guy!
This is what I get...
The rebuilt one that I have "in stock" has the black OEM pulley, not the billet pulley.
While packing stuff in the basement, I found a kit that I never used. If you want it, PM me and I'll send it to you for free. (This is for the original Hardin Gen 7 pump, not the Gen 7 Plus pump.)
FYI, I can no longer rebuild pumps because I don't have a hydraulic press -- or a workshop!
If it’s still available!
