Change Generator impeller on 2002 342 with 5E Kohler
any tricks to getting to impeller, doesn't look like a lot of room to get in there with access panel facing bow.
was running Genny and noticed exhaust sound got loader so immediately looked at exhaust port and no water coming out, so I assume impeller is shot or yellow coupler failed or impeller spun on it shaft.
any help would be appreciated, thanks
Oh and it helps to have someone else on the boat just in case you get stuck and need some one to help pull you out....been there.
