Access to transom stereo remote
For anyone who has changed out the transom stereo wired remote, what is the easiest way to access the back of this remote?
Sold - 2008 350 EC -- Greenwich Bay, Rhode Island
For anyone who has replaced these - the old Clarion on the transom was a CMRC1-BSS. Those types of remotes are hard wired. They have a mounting stud on the back for an electrical connection. (The same for the old MW-1 on my dash). Now the transom unit is a 6 pin. The new MW1 is an 8 pin. I bought a 6 pin to 8 pin adapter. From what I have read (and there isn't that much information on this believe it or not), the new MW1 (which doesn't have any mounting stud for power as the unit is supposed to just work with the 8 pin cable) is supposed to work. You won't see any lighting or the display screen, but the buttons are supposed to work. Nope. Nothing. From the limited information that I saw online, one guy had to remove the power from his old MW1 on the dash, which allowed both new style MW1 to work (buttons only not the display).
As for now, I am fine with having the dash remote work. I replaced the transom one because it was cracked and I was hoping that the new MW1 would at least be able to control the volume.
If anyone has been down this road and has information to add or offer, it would be appreciated.
I've travelled that same stereo path you are on. Clarion upgrades, remotes, Kicker, JL Audio & Fusion.
I would save up & do a proper revamp. Clarion works well - when it works. But have a good look at the newer marine brands. The features & quality are far better now. Tech has moved along dramatically recent years. Wired & wireless remotes.
Our last revamp....we hired marine pros for the install. The cabling & neatness & proper set up is worth every penny when you pay the pros.
Fusion stereos (Garmin) are awesome. JL Audio exceptional as well.
At the marina I guess it's a pho pa to have music going...there aren't really any raft up parties my end of the river. Sometimes sitting or running yes on the music but I got bigger fish to fry it seems to deal with...
If this works and it buys me a couple of years, then by that time, I am sure technology will have come up with some great head units and wireless remotes that will fill those spaces. Worst case, it doesn't work, but I have a new looking remote on the transom that looks pretty and is functionless. For now, I am okay with my current head unit. Replacing the speakers 2 at a time with the Polk ones recommended from the forum and noticing a difference.
If anyone needs a new style MW1, let me know, I am hoping to have a spare one available!
Has anyone pulled/installed new remote wires on a 350 EC?
Looking for any tips or advice on pulling new remote wire from the head unit in the cabin cabinet (starboard side) to the helm for the remote. Is getting a fish tape through pretty easy (or difficult)?
Getting a fish wire into the main panel area is pretty easy. Remove the speaker at the helm and that will give you a good visual down into the main panel area.
Disconnect all AC power (I disconnect at the pedestal) and remove the 2 screws holding each electrical panel in place. I remove the cabinet doors so that there is more room for the electrical panels to swing open.
More to come on this and I will share pics if this upgrade works out like I am hoping.
So this has been bothering me for a couple of years as I have been trying to upgrade the Clarion remotes trying to match the Clarion head, even going so far as to buy the 6 to 8 pin adaptors. Then I find out that some of the older remotes had a spade on the back of them for a power connections...and some of them do not. Well, Clarion finally stopped making the MW1 remote last year - and you cannot find them anymore (except occasionally on Ebay for $200 for a used one).
Well I've been going down all kinds of rabbit holes looking for the best way to upgrade. My speakers are all new, and my amp is good...so basically I just wanted a new head (with Bluetooth) and I wanted remotes. I looked at a number of brands, including Fusion (really nice) because they have wireless remotes. There were two problems that I was encountering - first was that most of the remotes were not big enough. The Clarion MW1 remote - if you pull it out to replace it, it has a 3" diameter hole. Not many options there. The second was the space for the head unit. In my 350 EC -it is in the electrical panel - single DIN and not much room for a bigger unit.
I figured that I couldn't be the only one with this issue. So as I watched a ton of videos (basically google searched radio upgrade express cruiser). I came across a company in Long Island who has upgraded audio on a bunch of Sea Ray Sundancers. What he used actually fit for a Clarion replacement.
I was able to replace both wired remotes - the one in the helm and the one in the transom. And they covered the hole! (an added bonus was that they require a 3" diameter hole...bingo!).\
Yes, I ran all new wires for the remote. It wasn't too bad once you knew where to look for access. (Thank you @YYZRC )
The head unit would fit into a single DIN. The face was a little tight. I had to use a Dremel and shave a little bit off of the bottom.
When I was done, I sat back all proud of myself admiring my handy work...that is until I tried to close the cabinet door for the night. Well, silly me - I never thought to measure the depth of the receiver face. Turns out the volume knob sticks out a little too far to be able to close the door. After sleeping on it and thinking it over, I just decided to drill out a small piece on the inside of the cabinet door so I could close it. Otherwise I am really happy with the system.
I can control the different zones separately from each unit. You can play different things on different zones. And the displays on the remotes show the same thing as the head unit. So not too bad of an upgrade considering it has taken me a couple of years to come up with something!
Here are some picks.
