Bomar front hatch on a 342
John41John41 Member Posts: 112 ✭✭
I’m having water come in on my Bomar front hatch.iIt seems to be coming in from the bottom of the pictures underneath the window. If I push up on the window it comes up. I tried to seal it but it doesn’t seem to work Can this be fixed or do I need to replace the hatch?
  • aero3113aero3113 Member Posts: 9,466 ✭✭✭✭✭
    I would pull the piece of lexan out and reseal all the way around.
  • YYZRCYYZRC Member Posts: 5,349 ✭✭✭✭✭
    edited August 2024
    I would replace the acrylic. Any laser cutting shop can make a replacement. Use DOWSIL 795 to seal them. Do not cheap out and use anything else. The acrylic expands/contracts at a different rate than the aluminum frame and the DOWSIL allows for this.
    I bumped a thread where with more details.
    Post edited by YYZRC on
    I pulled mine out and replaced it. It isn't that bad of a job. If you have any skills with a router you can get the right shape yourself.
