How can I remove Fuel Tank on 1994 Captiva 209?
Notice fuel smell in engine compartment. Looked at all fuel fittings and separator didn't see leak Noticed fuel in bilge area so fuel must be seeping some where at tank. How can I get to fuel tank and replace? Any help will be appreciated.
Check your fuel pump. If the clear hose came off the pump or the carb, gas will pump into the bildge if/when the fuel pump goes bad.
Thanks youstolemybeer for the suggestion. I checked as you suggested and didn't see any problem with the hose. Would be great if that was the problem. Fuel seeps really slow running beneath tank thru the drain holes into bilge area. Unfortunately looks like problem with tank.
