Engine hatch acting up
My 2008 330EC is having issues with getting power to the hatch actuator. The motor works in both directions( i jumped power to the disconnected motor), but the switch does nothing. The fuse doesnt appear to be popped on the rear panel, and it quit very suddenly, ie, working 1 minute then dead the next. Is there a relay somewhere i need to check or maybe the fuse is no longer functioning? Batterys are fine.
If you have a pair of alligator clips you can jump/bypass the circuit breaker to make sure it's not bad...they do go bad, and IIRC the jumper posts bypass the circuit breaker, but YMMV.
yes the jumper terminals worked!!! Are there any relays in this system??
of course when i went back up there to troubleshoot i turned the batterys back on and everything worked. So now i cant do any checks. Like you said, probably the switch.. What did you buy to replace it? Contura II momentary on-off- mom. on???
Yes cause i opened the hatch already so it was stuck open...
'05 Rinker 360 Fiesta Vee
