Must be winter
Member Posts: 3,008 ✭✭✭✭
No posts for 2 days…..
Hopefully there will be a lot of activity here shortly, March is right around the corner.
You know washing machines sometimes shake like crazy in the spin cycle, right? Well, the drum has a concrete counter-weight to help keep it balanced. It's held on by two bolts, one of which apparently fell out. Eventually the other bolt broke, so the weight fell off. Without the weight for balance, the drum went crazy and bashed into the control panel. As part of the mayhem, something caused a short that burned up the primary power relay and almost started a fire.
Bottom left, concrete counter-weight. Top right, toasted power relay.
https://www.jrmarine.com/instructions.htm
https://www.sterndrive.cc/Complete_Transom_Assembly.html?srsltid=AfmBOoqwwMwqOe0B_-b285RywVbO1u2AL8fjRhMGupYnWwEG8Pwvcuuv
