Arch lights replacement
cls10105cls10105 Member Posts: 356 ✭✭
Hello everyone,
I am looking to buy some lights for arch mine are in pretty bad shape. I have already talked to diggin about them.
My question is I have some bubbled up paint and missing paint surrounding the lights can anyone help me with suggestions on cleaning this up and what color paint to go back with
cruising on 6. tw0s
  • aero3113aero3113 Member Posts: 9,145 ✭✭✭✭✭
    Is your arch white or off white? If white, Rustoleum Universal is a perfect match. Sorry, pics came up out of order.
  • cls10105cls10105 Member Posts: 356 ✭✭
    Thank you so much! That looks great! Are you using filler or bondo or anything?
    cruising on 6. tw0s
    Thanks @cls10105
    I used Bondo. Cleaned the corrosion and old filler where needed then Bondo. Once painted, I let it sit for a couple days then polished with polishing compound. As you can see, I didn’t tape off around the areas that needed paint. By doing this it allows the paint to feather into the old paint and blends them perfectly. No hard paint lines. The polishing compound gets it nice and smooth.
    edited March 24
    This was done in April of 2021 and still looks great. But now I have some new spots to do.
    It looks great thanks for taking your time and sharing the photos and knowledge. I really appreciate it hopefully I can work on my spots this weekend.
    thanks again
    cruising on 6. tw0s
  • Liberty44140Liberty44140 Member Posts: 4,401 ✭✭✭✭✭
    Wow that does look great!!! Probably saw it in 2021 and forgot :) But what a great, and affordable, DIY repair. Nice.
  • Pat310Pat310 Member Posts: 579 ✭✭✭
    Does anyone have a matching color for the older off white arches?
  • FormulabenFormulaben Confirm Email, Member Posts: 146 ✭✭
    Not sure if it's applicable to yours or not, but I found this to be a very close match to my model.
  • IanIan Member Posts: 2,893 ✭✭✭✭
    I am not sure I am confident on my abilities to do mine myself.
    @Ian
    Give it a try, what’s the worst that can happen. You’ll end up having someone do it either way if you don’t like the outcome. It’s a very satisfying project and not difficult at all.⚓️
    @aero3113 where you got down to bare aluminum did you do anything to prep it like alkaline primer or vinegar before bondo
    Thanks @Formulaben I’ll give it a try
    edited March 25
    @Pat310 No, just cleaned with alcohol.
     I’ve had nothing but good luck with this paint. I used the satin finish version on a kitchen table and chairs that we still use daily in 2010 and it still looks great. I also painted the kitchen cabinets in the town house we used to own at the same time. I’m sure the owner that bought from us kept it, came out great. We were quoted $40k at the time to refinish the cabinets we couldn’t believe it, was such a tiny kitchen. I spent maybe $200 in paint 😂
    @Ian
    Yeah, problem is finding someone to do it. Only boat guy up this way did good work but unreliable and eventually a felon. Closest is Kingston and having to leave there.
    Maybe I’ll try a small spot.
    If you do have someone do it, doesn’t have to be a boat guy. Auto paint guy could do it. Try it first
  • YYZRCYYZRC Member Posts: 5,180 ✭✭✭✭✭
    My 330 arch had a huge crack. I ground it down, filled, primed and painted it with the same paint as @aero3113 is recommending. Turned out great. Patience is key.
