Running fridge on DC only
Liberty44140
                    Member Posts: 4,414 ✭✭✭✭✭
                    Our cabin fridge is an AC/DC refrigerator and freezer. All in one unit but freezer has separate door from fridge. The AC input stopped working. The control module is getting 122v but not powering the unit so it has to be a bad control module, I’m ordering a new one now. Runs perfectly in dc.
Any harm in running it on dc only for the next week or so until I get the new control module in? 50 amp charger is feeding two house group 31 so I think we’ve got plenty of juice!
https://citimarinestore.com/en/vitrifrigo-marine-refrigerators-freezers/14129-vitrifrigo-secop-danfoss-101n0510-ac-dc-module-100-230v-ac-1224v-dc-r101097.html
this units part number ends in 510. Yours and mine end in 500. The 510 is a direct replacement from the oem which just adds the capability for more electronics like electronic thermostat if you had it.
Also first things first, are you getting consistent dc in to the control module?
I’ll have to dig into it. First I’ll try the butt connectors.
Would the new module fix this? Is the Amazon part fixing something different not within the module besides giving more voltage?
Had Rinker used 12ga wiring to the fridge, I believe this would not be happening.
I was looking at the little computer fan on the back and was wondering if it worked. I turned the fridge on and it wasn’t moving. I stuck my pocket knife in and spun the blades a couple times. Sure enough it started spinning!
We’ll see! ⚓️
I’ll do the same with the WD-40 mine seems a little louder than it should be. ⚓️
So passing on the same to you. Do your connections, but change the fan. I ordered one from Amazon yesterday and it is already on my porch. $12.50 delivered.
