Fuel filters and such
rasbury
Member Posts: 8,856 ✭✭✭✭✭
So...I just pumped out 50 gallons of non ethanol fuel I suspect aged out. The boat would run but not plane out- wasn't missing just no power- so I figured the place to start- about 2 1/2 year old fuel with no "protection " . Do next is filters
but I'm a bit confused. My fuel line to the engine goes through a filter and right into the pump. No fuel water separator. I do have one for the generator and I believe another in line filter- this sound right? The big looking filter is the pump I used to pump out the has. The black filter is at the bottom right. The generator frame is disappearing.
The OEM screw on is an water separator filter iirc, just doesn't have the inspection bowl. A bowl isn't something you want hanging next to a hot gas exhaust manifold.
Yyzrc mentioned yours looks like it's been replaced so you might be able to add something but I'd call a tech line at defender or maybe west marine to verify they have one rated for inboard use. You dont want to add a fire hazard.
I'm going to have to do something with that gen set frame as it is absolutely crumbling. Let's take some painted steel and put it in a damp bilge to see what happens...I don't think it does anything for noise, just making a mess-
'05 Rinker 360 Fiesta Vee
