2003 Rinker 342 FV smartcraft
RinkerLifeRinkerLife Member Posts: 7
Hello all,
I have old analog gauges which are problematic to say the least.  I have purchared the Smart Craft and Nema 2000 network for my rinker.  The cables provided to me to connect to my dual mercruiser 350 horizon engines have a plug that I can not find on my motor.  Everything I have been able to find it my round 14 pin connector should have a 10 pin cam connector, which I cannot locate on my motor.  Any help would be much appreicated.
  • tricountytrailtricountytrail Member Posts: 227 ✭✭
    This is the plug you want.
    Top pic remove yellow terminator plug install cable to jbox.
    Def read though the old posts here about members installing these and working out the kinks.  Everything from simply getting the right components, what wires to use, reprogramming ECU's so one is port and one is starboard to simply figuring out answers to questions.  I chased gremlins for a while till I got it right.  Even simply starting your engines in the same order is important.
  • grouch0jrgrouch0jr Member Posts: 16
    Is reprogramming the CPU something you did yourself? I read elsewhere that you need to take it to a mercury tech to get that done.
    2006 342EC
  • YYZRCYYZRC Member Posts: 5,325 ✭✭✭✭✭
    Yes it needs to be done by a tech with the Merc diagnostics tool.
    I did mine myself with a Rhinda ECM tool.  Best money ever spent to be honest.  $500 and it let me read any faults that happened and reset them. But yes.  If both are programmed as STBD then smartcraft gets confused.  I am kind of glad i tackled this on my 342 as it truly made me appreciate how easy it is for just a single engine vessel.
  • IanIan Member Posts: 2,949 ✭✭✭✭
    Or the 555scan program will also and give/clear codes https://obd2allinone.com/555scan.asp
    I did it myself and could walk you through it not hard at all. and I will have the complete system coming off my twin 496 mag setup soon.
    X2 I use the Diacom program on my laptop. I gives better options for saving and printing in my option.
