over heating
toolmaker312toolmaker312 Member Posts: 127 ✭✭
After changing impeller,coupling, thermostat,over filling reservoir and using bleeding screw, I found an old thread that somebody put 1/8 barb with hose and sucked coolant through to get air out, generator now stays running.
  • grouch0jrgrouch0jr Member Posts: 120 ✭✭
    Where did you put the barb? Did you just leave it in place and cap it off?
  • toolmaker312toolmaker312 Member Posts: 127 ✭✭
    It is a 1/8in fitting with a Barb sticking out. I put a hose on the Barb and the other side of the pump hose into the reservoir. And as you pump the bulb on the siphon air was coming out and I continued until liquid started refilling the reservoir. I did have to add coolant in between to the reservoir
