Trim sender installation
oscar1
Member Posts: 803 ✭✭✭
I have to replace both of my trim sender and trim limit switch in my bravo III outdrive. I am wondering if i have to remove the drive to be able to get the cable pass through the transom or is it another way to do it. any advices would be appreciate. thx
I'd personally try to wait until it's time for bellows and gimbal if I had to pay to pull the boat.
If it's sitting on a trailer in your driveway way, it's a Saturday half day project. With an engine cherry picker pulling the drive is a one person 10 min job.
The furniture dollies also works great to move them around.
I know of boats that went over a decade without changing them...but I wouldn't be that lucky.
I'm not sure if there's a service interval to the cables other than silicon lube
Unfortunately @oscar1 the only visual you would see is a failure I'd suppose- nothing in-between.
The biggest trouble i had was the shift boot- it kept coming off- little scary there too. I only had one motor to deal with. Good chance to see the transom condition.
Good luck if you accept the challenge.
Also helps that most are low hours compared to what long distance cruisers or hardore fishermen would put on them.
My sister took ownership of my dad's approximately 2001 chaparral 3-4 years ago. Immediately took it to Wilmington NC and launched it in the ICW where she spent her first 3-4 weekends of boating time getting stuck on sandbars and running out of fuel. Still on the original bellow and gimball. Even original water pump alpha 1.
Just changed them out last winter and added navigation.
She lives life on the edge.
On the mercathode I would suggest asking chat GBT which has been extremely helpful on some recent projects- very tecnical details easy to understand. I'm no way an electrical guy and I'm sure someone will chime in- might start a new thread to get more attention.
