Oil change question
Since I have owned my boat, I have been changing the oil by sucking the oil out of the dip stick tube. But I understand that the two lines that are clipped to the transom between the engines can also be used. I have been avoiding touching them because they are rubber and didn't want to cause any leaks or anything. But was wondering how others do the change, using those rubber lines, or using the dipstick tube? I am betting that you can get a more complete oil change by using the rubber lines, as I only get about 4 quarts of oil out per change, and I believe my engines should hold at least 5. Just wondering what others do. Thanks.
X
https://www.baxterperformanceusa.com/evac-u-filter.html
https://parts.ilmor.com/shop/base-engine-accessories/remote-oil-filter-mount/
I've been curious if that would work with my engine, i just haven't finished my research yet. That purge system looks like a decent alternative for me if the Ilmore solution doesn't work. Maybe even better, less mess.
