Rinker Rinker Fiesta 360 2005 shift cable lengths
tricountytrailtricountytrail Member Posts: 262 ✭✭
Need to order shift cable for my Volvo Penta 8.1L with ocean drives?
Anyone happen to have the lengths?
I tried both ends and cant find a number.
    I would guess you just measure the length and get with Volvo and they would tell you what you need? With the length and motor info I'm sure you can shop on line as well.
  • Rich_Rich_ Member Posts: 371 ✭✭✭
    Numbers are not at the total ends of the cables, usually about a foot into the plastic sheathing area
  • tricountytrailtricountytrail Member Posts: 262 ✭✭
    Thanks I pulled out of the transom end couldn't see any numbers. I will probably have to pull them out and measure them both.
  • YYZRCYYZRC Member Posts: 5,609 ✭✭✭✭✭
    I would pull only one to measure so that you can use the other one as a fish.
    For the 330 and 350, the port side cable was 2' longer than starboard. I imagine the same 2' difference would be true for your 360 as well.
    Thanks it was the same for my data cables for the network.
    when I install my drives I will pull a chase line and pull them both.
    Anyone know how the cover comes off the throttles to remove the mounting screws?
    Its a top access but there is a trick to remove the outside trim cover.
