Springtime clean up
rasburyrasbury Member Posts: 9,025 ✭✭✭✭✭
Since I'm home now, I've really enjoyed some housekeeping in the cabin I never had time to do. Not that there are not issues to be taken care of, but it's nice to see i have time to devote to all of it- not shot gun blasting problem solving. Anyway, my face book feed seems to be pushing the latest and greatest for other than conventional compounds and wax for hulls. They tought a "ceramic" protection better than wax to keep the oxidation away..blah blah blah. I know I'm evoking a thunderstorm of opinion,  maybe even some coming to blows- does anything of this stuff work?
Our vessel has sat in the florida sun, no winter wrap for all these year, I'm 2nd owner. I have no idea how much gelcoat is left from wet sanding. 1st owner for sure had the $$ to pay someone for detailing. I did sand it lightly when we first purchased, I did not see any problems but concerned.  I normally use a 3M heavy duty oxidation remover and wax in one. Its a gentle "compound" that as you buff it in, the ruff disappears and it leaves a decent finish. I have followed up with a good marine wax but I can't measure if that was worth it. Who's trying any of the new stuff or just staying with your tried and true?
    I'm also interested in what people do for hull detailing. This was my first year with a boat, the blue is definitely oxidizing. I plan on buying a rotary polisher and putting the work in.
  • rasburyrasbury Member Posts: 9,025 ✭✭✭✭✭
    @grouch0jr don't get carried away with expensive stuff IMO. I bought one from harbor freight and it spins just fine!
    I use the 3M 3-in-1 also, and works well - and applies a wax
    Its not 100% but I don't want to damage anything and seems safe- thx
    While we are on the topic of detailing etc... I've got some stains at the water line of my boat. Do I need to get that off before compounding the hull sides, or will the buffing process remove the scum line?
  • aero3113aero3113 Member Posts: 10,082 ✭✭✭✭✭
    You will most likely have to remove it before. Just get some hull cleaner and it will wipe right off.
    A lot of the hull cleaners I've looked at say not to use around bottom paint. Any suggestions here?
  • Rich_Rich_ Member Posts: 368 ✭✭✭
    edited March 16
    I was actually shocked that the west marine brand actually did a decent job. The bottom paint warning probably has more to do with it changing the color a bit than anything else- not an issue if you get all along the waterline equally or plan to paint. Muriatic acid has been used to clean up the scum line as well, but be very careful around the fumes from that stuff as well as metals like a trailer Read a personal protection when using these types of products
    I'm not painting this year so i don't want to mess it up too bad.
    I would try the buff with the 3m product for lite oxidation which has some sort of material that acts as a compound material and brakes down to a wax somehow...then go postal on it if it does not work. You could take some 1000 grit with a block and give it a little rub with that...
    I used Star Brite Instant Hull Cleaner and the grime practically melted off. Thanks for the tips.
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    I've been happy with Star Brite also for the non-skid cleaner.  It doesn't take my wax off when I clean the bow, but it does keep all of my non-skid nice and white.  Later in the year I tend to get some little black dots (mold) on the non-skid, then I use the home armor (green bottle at home depot).  It has bleach, so lots of washing afterwards.
    Finally getting ready to compound my hull sides. Do you guys tape off your bottom paint, or should it be ok if I hit that with the polisher?
  • FormulabenFormulaben Confirm Email, Member Posts: 238 ✭✭✭
    I would tape it off, since the bottom paint comes off and gets everything dirty.
