Pro-Guide AGM Batteries
TonyG13TonyG13 Member Posts: 1,433 ✭✭✭✭
Anyone have any experience or opinions on Pro-Guide AGM batteries? Their brand seems to be popular on the bass circuit.
Looks like they meet or exceed the minimum power requirements for the Mercruiser 350MAG MPI DTS on a Rinker 310 EC (I believe it's 700 MCA/550 CCA/120 Ah):
Group 31 for deep cycle:
https://proguidebatteries.com/shop/pgm-31agm/
1000 MCA / 800 CCA / RC 205 Min @ 25 Amps
$450.95/each
Group 24 for starting:
https://proguidebatteries.com/shop/pgm-24mx935/
935 MCA / 750 CCA / RC 140 Min @ 25 Amps
$327.95/each
The reason I'm going with AGM is my Inteli-Power PD2100 Series charger only supports Lead, AGM, and Gel, but not lithium. - and don't feel like doing a deep dive to swap out chargers.
Thoughts - or just stick with LA?
  • Dream_InnDream_Inn Member, Moderator Posts: 7,907 mod
    I’ve had my share of different batteries over my 27 years of boating.  I used to be very particular with brands (die hard, interstate).  I’ve also done the types, LA, AGM, even TPPL).  My favorite for many years is from Sam’s Club, AGM Duracell.  I go with AGM for maintenance free and quicker charging.  And the price is very reasonable.  We’ve had many discussions here about brands.  IMO, it doesn’t matter too much.  Types do matter depending on what you’re after.  I also believe in a high CCA if for starting.
  • LaReaLaRea Member, Moderator Posts: 8,043 mod
    Ditto on AGM vs LA ... I love not needing to monitor water levels.  I got rid of every LA on the boat.
  • Cableguy GregCableguy Greg Member Posts: 5,075 ✭✭✭✭✭
    I changed my house batteries to AGM’s when I had my 280EC. Like Dream, I got the Duracell ones from Sam’s. They are made by EastPenn, the manufacturer of Deka batteries. I stayed with a LA battery for the starting one since Merc calls for 1000MCA.
  • TonyG13TonyG13 Member Posts: 1,433 ✭✭✭✭
    Thanks guys! Not a Sam's member, but they are having a membership special until the 30th. Got the "Plus" membership for $60. So will be picking up some new Duracell AGMs for half the price of the Pro-Guide.
    That is great Tony!  We are a plus member and the 5% back actually pays for the membership.  You’ll be very happy with the batteries!
  • grouch0jrgrouch0jr Member Posts: 190 ✭✭✭
    I just bought Duracell batteries (flooded lead acid) from Batteries Plus. I think it's a national chain, it's worth looking into if you don't have a Sam's membership.
    https://www.batteriesplus.com/
    That is where I have been buying my lead acid's. Unfortunately they don't have the right capacity AGMs that I'm looking for.
  • IanIan Member Posts: 3,050 ✭✭✭✭✭
    I bought AGM’s for starters a few years ago and they lasted 2 seasons. Replaced with sealed LA
    Went to Sam's today to pick up some new AGM batteries and I hope I didn't get the wrong thing.
    The Group 31 was easy. Picked up a 31DTMAGM for $215.
    Now for whether or not I got the correct starting batteries:
    Sam's does not carry Group 24 marine AGMs, but they did have Group 34 marine AGMs. I'd have to get the 24M at Batteries Plus.
    I did a quick comparison and it seems like the Group 34 should work fine?
    Group 34M (Sam's - $135)
    CCA is 750
    MCA is 860
    RA is 120
    Group 24M (Batteries Plus - $200)
    CCA is 550
    MCA is 730
    RA is 150
    Will I be OK with the 34M as my starting batteries?
    From what I understand outside the electrical spec is the group number relates to size so be sure it fits.
    I actually got a new 24 battery tray a while back so I brought it with me to Sam's. The 34 has bit a smaller form factor, length and height-wise, but width is about the same as the 24, and fits fine in the 24 battery tray.
    Sounds like you did well Tony!
  • Corral42Corral42 Member Posts: 68 ✭✭✭
    I’ve got agm under the bed at the bow for the thruster because it sees the most bounce. I have lead acid still for starting and deep cycle. Replaced this year with tractor supply marine battery brand made by interstate
    You definitely want sealed batteries when in the cabin, so it does not discharge gases.
