Solar charger
rasbury
Member Posts: 8,986 ✭✭✭✭✭
I have had some teal issues bringing my boat home to charge batteries and I need to come up with something solar to at least keep the start battery up. I've always, until recently, had issue with batteries discharging but that is resolved. I ha vv e regular lead acid type batteries, 2. What can I put on there that will at least keep them alive?
https://www.amazon.com/dp/B0C2H7BVY6
I imagine you'd want something with alligator clips so you can easily put it on and take it off without having to add real infrastructure to your boat?
I can't remember the cost but I don't think I had more than 250 in the set up.
I'd go with a quick disconnect set up unless you want to mount something to your arch, which means the arch never comes down. No need for a regulator or running wiring in a fashion that looks clean and factory.
The little 30 watt ones can be had for less than 20 bucks. And if someone decides to swipe it you're not out much.
They come with alligator clips or a cigarette lighter adapter.
