Pee pipe disaster
I'm not asking for advice for a change. I just wanted to share with you all, my disastrous pee pipe experience.
With a half full toilet waste holding tank, the hose going from the tank to the pump out point decided to split and I ended up with a lot of very stinky pee in my engine compartment.
Nothing, and I really do mean nothing, can prepare you for the job of baling out 50 litres of pee. I stank so bad and almost had vomit to add to the bail out. Thank God there was no poo in the mix.
I have now replaced all hoses and have an empty tank.
The shower I had after that episode of 'What did you do on your boat today', was the best shower I have ever had.
What have your worst disasters consisted of?
  • PickleRickPickleRick Member Posts: 4,408 ✭✭✭✭✭
    edited September 6
    Id be p i s s e d.
  • YYZRCYYZRC Member Posts: 5,605 ✭✭✭✭✭
    I had the elbow at the bottom of the poo tank fail and half a tank of pee and poo filled the bilge. Bilge pump kicked on and got clogged with toilet paper. I used a shop vac to clean it and threw out the shop vac after. Also a new bilge pump.
    When that exhaust air from the shop vac hits you when you are sucking up waste… what a time.
  • TickledPinkTickledPink Member Posts: 131 ✭✭
    edited September 6
    @YYZRC thats $hit man.
  • captkevincaptkevin Member Posts: 619 ✭✭✭
    That is no good. Makes me glad our boat does not have a bathroom to deal with
