Batteries over winter
grouch0jrgrouch0jr Member Posts: 282 ✭✭✭
What do you all do with your batteries over winter? I was getting ready to pull mine to put them on a trickle charger for the winter, and a handful of guys at my boatyard said they just leave theirs in boat all winter. They stop in from time to time and plug their boats in to top of the batteries.
I'll be plugging her in at least once a month to do some work, so my batteries would get some juice.
  • YYZRCYYZRC Member Posts: 5,585 ✭✭✭✭✭
    I leave mine.
  • aero3113aero3113 Member Posts: 10,084 ✭✭✭✭✭
    I leave mine in disconnected with a 4 bank trickle charger on them.
    I used to take them out and keep them on the trickle charger in the basement, what a pain pulling them out and then putting them back in!
    edited November 8
    Cords are long enough to leave the batteries in place. It’s placed in between the trim pumps above the transom.
    Where I keep my store it for the winter, I can't leave it plugged in. I can only connect power while I'm with the boat, otherwise I'd definitely do that.
    Is it inside or outside? If outside, can you use a solar charger to keep them topped off?
  • FormulabenFormulaben Confirm Email, Member Posts: 238 ✭✭✭
    @aero3113 has a good point.  I have a solar panel mounted vertically on a snowmobile trailer and it's going on year 5 of keeping the battery healthy in sub 20 degree weather, outdoors all winter!  No way it would have done as well without it IMHO.
    It's outside. That's a good idea, I'll look into it.
  • johnny44johnny44 Confirm Email, Member Posts: 138 ✭✭✭
    I remember years ago when I finally had a boat that had more than two batteries. Before that, when it was only one or two batteries, I used to take them home. One day I was looking at 5 batteries and I got curious about what others were doing. I read so many boat forums. Some very loud forum members would lecture about taking the batteries out and bringing them home, etc., etc.
    I kept reading. The batteries are heavy. They're in a hole in the engine room. My boat is a pretty good distance from my home. I don't have much space at home. Some people said that they just disconnected and left on their boat for the winter. So, that winter, I gave it a shot. Never had an issue with my battery life. Ever. I am sure some out there will argue with me, and that is okay. I am sure others may have a different experience than me. 10 years later, I leave my batteries on the boat, disconnected. No issues the next year, no issues with short life.
    Make a decision that you feel is best for you.
    Former Boat: 2008 350 EC
    Greenwich Bay, Rhode Island
    Leave in connected but switched off.
    I put a single solar panel up on the shrink wrap to power my Arlo camera. I also am not allowed to leave the boat plugged in.
  • PickleRickPickleRick Member Posts: 4,406 ✭✭✭✭✭
    I used to charge them fully then store in the off position all winter.
    I started getting 2 to 3 years out of the batteries.
    Now i leave them plugged in all winter and get 5 to 6 years out of the same brand batteries.
  • captkevincaptkevin Member Posts: 617 ✭✭✭
    disconnect & charge - leave in boat in barn
    I need a barn
  • Dream_InnDream_Inn Member, Moderator Posts: 7,979 mod
    Mine are in the boat and nothing different than any other time of the year.  She sits up on the lift, shore power plugged in.
    A barn would be awesome. Would love to have enough room for the boat and 2-3 vehicles plus a lift!
  • GrahamuGrahamu Member Posts: 923 ✭✭✭
    Load test each battery, if you have a failure remove it from boat and replace it with new at launch. Make sure the remaining batteries are fully charged and then remove the negative cable. we did this for a couple of hundred boats each year with very few problems. A discharged battery will freeze and crack.
    30' X 48' sounded huge when we were planning. Should have gone bigger.
  • SpyderwebSpyderweb Member Posts: 963 ✭✭✭
    With my earliest boats I removed batteries and kept them at home.  With a new bayliner 285 I didn’t have that option.  Dealer said leaving batteries outside all winter would be fine (northern NY).  Those batteries lasted 9 years.  After that experience never worried about storing batteries outside again.  Rinker is stored with batteries on board all winter inside cold storage.
    I was always told if you charge them before storage they can't freeze & would be ok. Used to take them out & store in the basement until spring.
  • echandler1971echandler1971 Member Posts: 248 ✭✭✭
    I take all 5 of my batteries out using child labor (my 24yo son  :D ) and put them under my basement workbench on a jumbo trickle charger. Then in the spring, more child labor. The key is child labor.
    Dan of Steel
    '05 Rinker 360 Fiesta Vee
    @echandler1971 , I’ll have to wait a a few years. The batteries are a little heavy for 7 and 9 year old girls 😂
    Ahh but at least you can get them under the engines to fish out that non-ferrous tool you drop down there….
    It is amazing what you can do when you are young and agile (& not smart enough to say no :smile: ).  My son is now 24.  Probably 4 years ago I had him under my port motor changing out the starter.  When I say under, I mean his head went between the oil pan and the stringer, with only his legs sticking out from under the motor.
    @Dream_Inn I was in that position tightening the oil pan bolts. I was afraid I was going to get stuck. And I had my phone up in the cockpit 😂. I actually think there’s room to drop the oil pan if I wanted. Wouldn’t be easy but doable.
