360 swim platform support broke free
echandler1971
Member Posts: 248 ✭✭✭
When I went on the hard, I saw this beauty. Obviously the bolts rusted off. My question is, what should I do to reattach? Whatever I do, I’ll match the other side that will likely have the same problem. I’m more wondering about through-hull or lags short of through hull. If the latter, how long a screw is that?Dan of Steel
'05 Rinker 360 Fiesta Vee
Coat the inside of the transom with 2 part epoxy. Usually with q tips. Tape over the inside of the hole. Before it fully dries mix up some thickened epoxy about the consistency of peanut butter and inject it in with a large syringe. Double check your inner hole is flush and toss some more tape on the outside making sure shes good and flush with the outside of the hole too.
Let it cure. Now drill the hole for your 1/4" screws through the center of your epoxy. Clean, add your 4200.
If the sealer ever leaks your transom stays tight and dry.
Same for trim tabs or anything drilled through wood core. A dry core is a long lasting core.
