center window for a 2000 Rinker 212 BR
justmejustme Member Posts: 3 ✭
looking for center glass for a 2000 Rinker BR 212
  • aero3113aero3113 Member Posts: 10,087 ✭✭✭✭✭
    Is it flat or curved? Any glass shop can replace it if flat.
  • justmejustme Member Posts: 3 ✭
    it is curved
  • FormulabenFormulaben Confirm Email, Member Posts: 239 ✭✭✭
    There was a window for many of the mid-2000s wake boats that was breaking far too often due to wind slamming it shut when left open.  It was made by Taylor Made/Lippert and was no longer in production. Since it was curved many were seeing ridiculous prices for the replacement part, so a lot of those owners started moving to plexiglass since it was cheap and far less likely to break if the pass-through window were to accidentally slam (broken) again.
    I'd check the local glass guy and see what a curved plexiglass replacement is if you're open to it. It bends easily with some heat and should fit in the frame just fine if cut accordingly.
    PRO TIP: use Pledge furniture polish on the plexiglass; it hides small scratches and makes later cleaning much easier.
