2007 280EC Kohler Generator
Has anyone had an error code EC09? We have a 5kW generator on our 280 EC. Wont even attempt to crank and had zero issues before. Any ideas?
Thanks Hamdog
BD, just got the manuals and checked the fuses, going to pin out the harness from throttle sensor to ECM tomorrow. Yes its fuel injected, the problem is you have to change the entire throttle assembly!
ooo That sounds like $$. if you need parts, these guys are good, I've used them in getting my 5e running:
http://www.partsfortechs.com/asapcart/generator-parts-kohler-c-14_83.html
I have caved in and have a Kohler service guy coming out next week. Will post the solution once fixed!
Hi RY, No the service guy is not returning calls, looking for another contractor. This is frustrating. But at least we are still boating!!
This is getting frustrating as we are planning to anchor our Labor Day weekend. I cant believe that I am calling them on a daily basis and no return calls. I talked to the guy and he sounded like he is good on Kohler generators. I will try again today, but I was also thinking about unbolting it and sliding it forward to double check all the harnesses are connected correctly. It's always the last issue to be fixed takes the longest to fix!! Oopp's I hope I didn't jinx it! BTW, EC09 code has gone away and now I have EC12, leads me to thinking a connector has come off.
Have you called Kohler Marine direct? They can be a help, or get you to a dealer who can help. Total Energy Systems in WI might be worth a call and can point you in a direction Toll-Free: 888-548-1400
