Battery Switch
Do you guys run with the switch on both, 1 or 2? My boat has an isolator, I'm new to battery isolators and not sure what I should keep the switch on.
I normally will start and run on 1 then switch over to 2 when anchored. Do I have to play with the switch or can I leave it on both?
Chapmans.......
Here is a pic of how the battery's are set up. You can see the isolator on the wall to the left and the two red power wires that go up to the switch. (This pic is when I first got the boat,everything is much cleaner now)
I didn't get to that chapter yet! LoL
I am pretty sure it will charge BOTH batteries regardless of where the switch is at.
My switch looks like this, and the only time I ever put it to combine is if I ran the starting battery down and needed the house battery to start the engine. And vice versa if I ran the house battery down and needed to use the starting battery for a 12V function like the GPS.
I have 2 dual purpose batteries. When I get some time ill try and test like you said.
This is a really good idea as my old 242 was wired so both batteries work for starting and house. There was no isolation regardless of switch position didn't find that out until I ran both dead at the same time.
Start/Run on one, anchor on two. Both should charge in any position. Do not anchor with both "on" or you risk running both down below starting capability. You only need to combine both if both have been run down to where neither will start your engine independently - this is called the Hail Mary setting. MT
with the isolated set up .. And a battery seletor. I start and run have the season one one battery then the other half on the other. What ever battery is being used should both start and run the house. If you run it dead flip switch to the other battery to start the boat. Use both as a last resort. Start up is **** batteries, that's why I alternate. Some people alternative every other trip out. If you slip your boat turn it to all off makes it a little harder to steal it.
btw the belge pumps should be fused but wired directly to one battery. If you get in a boat taking on water start boat. And turn on both batteries.
I use # 1 for cranking and # 2 for house etc.. I turn it to both if just cruising to charge both at the same time. Not sure how I came to that conclusion.... maybe dreamed it or something!
