Leaking Canvass
Well not actually the canvass and not really the zippers but where the zippers are attached to the boat. Any clues on how to stop this?
Had to do that to mine several years back.
Thanks for the tips. I will see what I can do next weekend.
I really believe it is leaking from the U channel on the arch. Capt Ron suggests a tent seam sealer. I googled it. Lots of different kinds. Would you suggest a spray on application or a tube application?
Thanks.
Tube. Apply where needed.
I used this when I replaced the zippers...from Sailrite.com
http://www.sailrite.com/Iosso-Seam-Sealer-4oz
The U-channel can have leaks in the seal which may need to be re-selaed...for this job I used outdoor silicone...I found two spots where the sealant had disappeared, and needed touch-up....the leaks are gone...
Do you have to take the U-channel off or do you add sealant on top of the U-channel and arc?
Don't take off the u channel, just caulk the seam. [edit] Pulling the channel off is a pita and you can pull the arch paint off too, been there. Let alone the trouble of getting the screws out and back in again as the holes can strip out easy. I had to redrill several. just clean the joint on the arch/uchannel well to remove any wax and caulk.
Ok, Thank you. :-)
