Sewer smell
lesles Member Posts: 24 ✭
I have orange filter system but there is still smell after every flush. What is remedy to fix this on my 270
    How old is it?
    Sin or Swim - Rinker 312
    1. As noted above, how old is the charcoal in it?
    2. Hoses connected to it?
    3. Hose connected to tank?  Mine was connected badly..wrong size tubing at the holding tank fitting
    4. Look for cracks on the tank or a loose sensor.
  • lesles Member Posts: 24 ✭
    2 years old. Maybe it needs to be changed?
    edited August 2014
    You should change it annually.  Go from there.
    I do mine every year and never had that fine small overtake my boat again.  Now I just smell others :P
    I will try that this weekend. Thanks
  • Capt RonCapt Ron Member Posts: 217 ✭✭✭
    If you got the charcoal wet because the waste tank was over full, then you need to replace the charcoal. I just replaced mine after three years of use. Although it was still working, the charcoal was pretty smelly after three seasons.
  • OldDogNewTrixOldDogNewTrix Member Posts: 166 ✭✭✭
    Make sure to change the foam piece too. You can't wash that smell out of it, believe me, I tried.
    Wayne '09 340 EC
    Just replaced all of it this weekend and now works great. Thanks for advice
