i have a2004 282 refergator works on 12 volt but not on 110 checked ,power good
miker01miker01 Member Posts: 4
  • raybo3raybo3 Administrator Posts: 5,614 admin
    Are you sure it is supposed to work 110vac? If yes maybe the plug fell out. Pull out the unit and check for the connection. Could also be the built in inverter but make sure its getting power. Good luck and keep us posted
  • miker01miker01 Member Posts: 4
    thanks yes it does work on 110 has been working fine,puled it out checked plug and voltage 110 volt to the control box
    where do I get a new power inverter
  • pepmysterpepmyster Member Posts: 308 ✭✭✭
    Check your local supplier of that fridge. They should be able to get it for you.
    I got one on Ebay for something like $70.00 and was pretty easy to install.
