JABSCO PAR MAX 2.9 water pump stopped working for no reason all of the sudden?
lupingladelupinglade Member Posts: 9
Our JABSCO PAR MAX 2.9 water pump has suddenly stopped working. It was working less than a week ago. Last thing we did is pump out water to clear out winterizer residue. It was working just fine. Today it would not work. The breaker is not tripped. The pump makes no noise whatsoever when taps are opened. The water tank is of course full. Any ideas on what could be wrong?
  • ScottKScottK Member Posts: 26 ✭✭
    Could be the pressure switch is bad on the pump
  • SandkriceSandkrice Member Posts: 20 ✭✭
    My 06 270 had the same issue over winter. Worked to drain tank in Oct. but didn't work in April. I bought a new one for $88 and replaced this weekend. Fairly easy fix. Good luck!
  • cettialpha6cettialpha6 Member Posts: 42 ✭✭
    First check for kinked hoses, before replacing anything, just to make sure.
    Check for inline fuses replacements sometimes come with one mine did and i cut it out.
  • lupingladelupinglade Member Posts: 9
    Yes, had to replace it. Its not the pressure switch (tried bypassing it). The motor was dead. Easy to replace. Thanks for everyone's input!
