Sony Marine Wired Remote
dropout
Member Posts: 138 ✭✭✭
2005 Rinker 300
I have two Sony Marine Wired Remotes RM XM10.
I am replacing the receiver with a new Sony. The problem is Rinker cut the audio cable from the remote and hooked up a 4 wire plug and then wired that inside the old receiver not needing to use the audio jack. Now I need to convert what they did so I can use tha audio jack.
(no changes to the datalink, still using)
So confusing even more confusing to explain.
Any ideas on what to do in order to get the remotes to work?
This is the plug that was was installed by Rinker. The "headphone jack" on the back of the remote was cut and replaced with this and the other end was hardwired into the receiver. I need to revert back to the "headphone jack" in order to plug into the new Sony.
Any ideas?
I have the same problem and need to replace that plug with something that goes into a small blue mono-audio-like plug
Anyone know the wiring? The orange wire on the plug was not connected, at least in my boat...
The remotes are MRC2 SONY compatiblle...and the wires are black, red and white....
The head unit takes a three wire 3.5 mm TRS, like a stereo headphone jack...
The problem is to wire the TRS jack correcly....
Tip= ?color
Ring= ?color
Sleeve= (always ground) ?color
Any suggestions?
Got it!
black = ground = sleeve or unshielded in stereo jack
red = ring = red inTRS (tip-ring-sleeve stereo jack(
white = tip = black in TRS jack
Both, cockpit and helm remote controls work now.
