Water leak in Bildge
dazeoff03
Member Posts: 3 ✭
I have a litre an hour water leak .Hours have been spent trying to find it ..It doesnt appear to be on the engine anywhere .hoses clamps drains all dry..AND it only leaks when the boat is moving .......We have had the engine in drive and used mirrors ect. to no avail .We even tied paper towel under the engine and rear area .........dry.............The water is cold and clear .....Would a shift bellows do this ????.. Any help would appreciated , before i lay in the engine compartment while the boat is moving at a good speed ..Tell me it cant be the seal on the transom yoke ,????? please
Daze. What boat we dealing with here? What drive? Have you checked all thru hull fittings? Does your boat have fresh water system? If so have you checked all fresh water fittings etc... Certainly could be shift bellows but you would think that it would leak all the time then unless it is a very fine cut and only let's water in when you turn the wheel or something. That may be something to try. Start engine and while in neutral turn the wheel back and forth to see if that triggers the leak. Something else to try might be to get some paper towels near the bottom of the transom area to see if they get wet at least that will narrow down the search a little. Not sure what you mean by seal on transom yoke. You mean the gimbal ring seal? If so you should be able to see this by laying on top of the engine and look where the steering arm goes through the transom. Shove some paper towels in there and see if there is moisture in there. That was my problem a couple years ago.
Let us know on the above and we will go from there. Good luck.
Welcome,
do you have a raw water pump? My friends fitting was loose and it leaked while underway only because it had a special pick up to get water while on motion.
Check the speedo pitot tube behind the engine on the transom shield. The plastic fitting breaks easily allowing water into the bilge only when underway.
Mark
2019 MTX20 Extreme
Only water during running not sitting. Hummmm...
Bellows really only leak when sitting. On plane the are out of the water.
Engines dry but water in bilge....
So my logic takes me to a forward compartment as the boat planes water moves south....
Check freshwater system for leaks.
Check shower sump for leaks. Like a lose top.
There was a recent thread about bravo 3 steering pins leaking. I have water in my bilge & suspect this is the cause. I'm bringing my boat to a merc dealer for winter storage & will find out for sure. If your leak is through the steering pin, you will be able to see it. The other thread has pictures posted that will show you where to look.
I'm not sure if running or not running matters for the steering pin leak??
I just found out one of my bravo III's is leaking where the steering arm goes through the transom. It only leaks when the boat is sitting. Good luck.
Ray
2006 390
Previous 2000 340
Looks like that is also going on in mine.........
Highly recommend the JR marine fix to you guys. I'm on my second year with it and no problems or water at all.
Yes, I agree with the above. The Stainless steel steering pin from JR Marine is not only superior to the Mercruiser pin, it is much less expensive. They even have a 30 minute video on how to perform the job. (if that's your problem)
I installed a mercruiser pin 10 years ago in my 1992 Rinker 260. It lasted 10 years, but started leaking again. I went with the JR Marine to save some money and put in a quality pin.
www.jrmarine.com
Can you pls send me the list as I am going to order two. Only one is leaking so far but might as well do both of them.
thanks.
Paul
Paul
Ray
2006 390
Previous 2000 340
