Newbee here...anyone tell me where the low pressure fuel pump ccan be found on a 2004 282
flyguy1117flyguy1117 Member Posts: 6
Well, the 4th of July Holiday weekend starts tonight.....it looks like the rain will finally stop..... and now my boat is inop due to a bad fuel pump.......
I'm thinking about changing my low pressure fuel pump myself vs waiting for the Marina to get to it.  My question is can anyone tell me where it's located and if it is in fact a DIY job or should I wait.  I have the replacement pump in hand and it appears to be very easy to install.  I just need a little guidance/advice.
I have a 282 2004 with a small block engine.
Happy Boating!
Best Answer
  • flyguy1117flyguy1117 Member Posts: 6
    Thanks!  I'll look for it there.  So it sounds like it's mounted on the engine near or over the top of my water separator filter..no need to respond unless I'm way off.  Thanks again! Joe D.
    Thanks for the help it was exactly where you suggested and was replaced fixing the issue!
  • raybo3raybo3 Administrator Posts: 5,614 admin
    Glad its fixed. I see it only took you a year.......lol
    It took me a year to realize I needed to answer the yes or no question showing that the answer helped.....a years not to bad right?  May be I can get it done in under 8 months next time.....LOL
    Bottom line is your floating and hopefully having fun.....
