Smart Tabs installation question - 2006 Rinker 226 Captiva
I am planning on installing Nauticus Smart Tabs on my 2006 Rinker 226 Captiva. I was wondering if there is any problem drilling into the areas I've highlighted in red in the picture. That area seems more solid than the rest of the hull when knock on it. I just want to make sure I'm not drilling into metal or something I shouldn't be.
Post edited by Babyboomer on
I put my Smart tabs on the transom closer to the stern drive and the top of the cylinders mounted on the curved portion. I'll post a photo tomorrow. In any event, you shouldn't have any mounting issues with your location.
Mark
2019 MTX20 Extreme
Food for thought. BTW, they work great!
Mark
2019 MTX20 Extreme
Agreed; however, in my configuration, lateral stability is not an issue and work perfectly. I did a 192 this way on the advice of Nauticus and it too worked out very well. Either way, you can't go wrong.
Mark
2019 MTX20 Extreme
Thanks for the replies, guys. MVN, I first considered mounting them there too, but Nauticus has a picture on their website stating that that is too far inboard. That's the reason I was decided to mount them in location I pictured above.
I have heard that many people put them next to the stern drive like your setup on the advice of Nauticus if they cannot find a better place. I'm glad they are working well for you. I think I am going to stick to the location I have chosen. Hopefully I don't run into any problems drilling because that area is definitely more solid than the surrounding areas of the transom.
Mark
2019 MTX20 Extreme
Boat: 2004 232 Capitva CC
Boat Name: Mixed Nutz
Here's a photo I found online showing conventional tabs mounted on a 226.
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
Excellent! You'll notice a huge difference.
Mark
2019 MTX20 Extreme
2019 MTX20 Extreme
engineer here. fluid mechanics dictate that from a list-correction standpoint, the farther out you install tabs, the more effective they'll be and you'll need less deployment for correction (which means less drag, higher speed, and fuel efficiency).
From a “getting on plane” standpoint, it does not matter whether they're in or out.
so if your tabs are usually deployed equally (or close), no difference. If you're trying to correct a list, then you might want to consider going out a little bit. but you won't notice a HUGE difference. Mostly those trying to eek out every last drop of speed and fuel will notice or bother.
Makes sense. I wasn't trying to correct a listing issue, just preventing a porpoising issue and trying to reduce minimum planing speed.
Mark
2019 MTX20 Extreme
Here's a photo of the precursor to the 226 I think. It's a 2007 R1. It has a very similar transom design to a 192 and possibly a 212.
Mark
2019 MTX20 Extreme
