My 2005 270 FV has a tach that will not read steady.
sbode
Member Posts: 10 ✭
When you try to set the engine for 3000 rpm the tach will bounce from in the 2000's to the mid to upper 4000's. It does seem to stay more consistent when you are up at the 4000 rpm range. Occasionally it will just stop the bouncing around and run steady for a while but not often. I am starting my research before i try anything. I prefer to do this type of work myself instead of going to the local dealer but also not opposed to that plan if necessary.
Best Answers
MarkB
Member Posts: 3,999 ✭✭✭✭✭
Faria gauge is my bet. Tap the gauge with medium force and it will steady out. Or spend a few $100 and replace the gauge with something a little better.Boat Name: King Kong
jmoen438
Member Posts: 98 ✭✭✭
It's a Faria, I have the same boat and mine does the same thing. Couple of taps will even it out.
does not work properly .
x
