Auto pilot on 342 Fiesta Vee
DakotaSkipper
Member Posts: 8 ✭✭
Hello, I am thinking about installing an auto pilot on my 342 Fiesta Vee. Does anyone have any recommendations on brands and models? Are there any issues or problems any one has experienced with an auto pilot unit on this size of boat? Thanks for any responses.
Dakota Skipper
Best Answer
OptionsLaRea Member, Moderator Posts: 7,567 modI just installed a Raymarine Evo on my 370. I love it and use it almost all the time. I had a Simrad on my 342 for ten years. Autopilot is a wonderful tool for the way I use boats.
For a new install, the choice of actuator is important. On my Simrad, I had a linear electric actuator that was very easy to install, and lasted nine years before I had to replace it. On my current setup, I have a rotary cable-driven actuator by Octopus. It was harder to install, and it added some resistance to the steering. Before the install, I could easily move the wheel with one finger. Now, with the Octopus drive, steering requires a noticeable effort. (It's still quite easy to drive, but I only notice it because of the difference from before.)
Do you have Bravo III outdrives? If so, you'll have a limited selection of actuators, and it's hard to find good info on the web. The Octopus will work with any brand of AP. You should call Raymarine and Simrad and see what setup they recommend for your boat. Or, find a good local outfitter who has done AP installations with Bravo III boats.
What is your current chartplotter/GPS? Are you upgrading that at the same time?
Be prepared to spend a few bucks on network cables and connectors if you want your AP, GPS and VHF all talking to each other.
In my case, the total cost was higher because it was part of a larger helm upgrade. I added a Raymarine I-70 display -- same form factor as the R-70 autopilot controller, but it will display any data available on the network.
One thing I love about the Raymarine system is the rotary knob for changing heading. Suppose I'm cruising along at 34 mph, and I spot a constant-bearing-decreasing-range target (i.e. a boat that I will hit if neither boat changes course). All I have to do is reach down and flick the heading knob a few degrees to starboard. My boat will take enough of a turn to show the other captain I've altered course, and then it will stay steady on the new heading. Predictable is safe!
Thank you Everyone.
Dakota Skipper
Thinking about installing an AP as well, using an Octopus drive and the EV-200. Just a question. When not in use, i.e. driving with autopilot on, is there any difference in the strength required to turn the wheel. Someone on another forum mentioned that it was very difficult to turn the wheel after installation of the AP (I doubt it, but wanted to be sure).
Thanks,
2004 342 Fiesta Vee
